Hi everyone, this post will be all about my adventure into sound deadening my rattle box and trying and hoping on making my Rav quiet enough to me and getting rid of all those rattles. First, let start by saying this is the first time I ever venture into installing sound deadening into a car, which means this will be a learn as you go experience. I'll be more than happy to answer any question as the project go if I can answer them.
This project will consist of improving the sound insulation into the Rav4 in a why that will hopefully reduce road noise and random door rattle. To do this, I am anticipating on doing the following areas:
For this project, I'll be turning my-self to a product called Butyl made by Noico. This product is about 1/3 what Dynamat cost and is really similar. This can be bought on Amazon. Installation is as simple as laying it down and rolling it with a roller.
Few things I've learned from the door I did on Sunday. This product is easy to apply and you don't need to heat it. Just lay it off in the sun and it's maniable. The process is not hard per say but is time consuming. A single door took me 3 hours and about 5 sheets of material.
I also learned that our doors are made of 2 layers of thin metal. I'd call it an inner skin (inside the door) and outer skin (where you can see the speaker). I am not 100% if one could disassemble the outer skin to gain easier access to the inner skin, but I was personally not confortable tinkering with this. I simply decided to remove the white plastic of the outer skin to gain access to the inside and do my best to reach and apply the material. Also, I to know if a difference is made, I took a few sound reading. Going 115km/h on the highway, I hit a an average of 86db. Baseline was 48db with engine off.
Now enough bla bla and here are a few picture of the first door.
- The 4 door panels (As per the picture, you need to do the inside door, the door panel and the plastic panel.
- The Front pillars
- The center console (Where the shifter and armrest is)
- The Trunk
- The entire back of the Suv (Spare area, fenders but I am not touching the roof)
- The hood
