261 - 280 of 293 Posts
Has anyone put anything above the headliner? I switched from a Thule rack to Prinsu to decrease wind noise, and the Prinsu is definitely a quieter rack, but I still hear it. To install it, you have to sag the headliner, and there definitely isn't anything up there between the metal and the headliner itself. I think some of the deadening material up above the headliner could certainly make a difference for anyone who has an aftermarket roof rack or has their crossbars installed.
Here is a link to the install guide if anyone wants to give it a shot. I probably will someday.
Prinsu Install Guide
Check out ravrduckee on IG. He installed the Prinsu rack and applied Noico 80 and 170. I reached out to him and his Initial impressions indicate noticeable heat reduction but not a whole lot of noise damping. I’m more interested in the heat reduction application but am a bit disappointed in the noise damping results. Perhaps a double layer of Noico 80 might yield better results noise-wise.
Has anyone had any success with Mass Loaded Vinyl(MLV) in the doors? Something like this Luxury Liner Pro™ Sheet - MLV + Foam
From my research most people suggest the damping stuff like NOICO 80 then MLV to really reduce road noise
The proper way of going about these projects is to use Noico 80 mil and then apply Noico Red 150/green 170 mil (or any other brand of sound deadening foam) on top. Most will be satisfied with the Noico 80 alone and the cost of the project (money and time ) doubles with the second layer. So yes, if it’s in your budget, do apply a second layer of foam material such as the one you identified.
I think I’d consider luxury liner pro if the glass were acoustic. Doesn’t matter how much you add to the doors: the floor and windows will be your leading noise contributors after doing just a dampener on the door panels.
'19 XLE
For anyone combing through this thread and looking to quantify results from sound deadening:
I went back and thoroughly applied the Noico material in the cargo area, underneath the back seat, and in all four doors. The attached pictures are the final result. Additionally, in the cargo area I used some Boom Mat sound deadening spray which is the black finish you see in the cargo area. I don't recommend the spray as the can seemed to evaporate and it didn't make much difference other than aesthetics.
My updated decibel readings:
I used the same free sound app on my iPhone (Decibel X) to take the following recordings...
0 MPH with engine warmed up: 50.6 decreasing to 44.7
30 MPH: 64.1 decreasing to 59.5
60 MPH: 68.2 decreasing to 66.5
I notice the biggest difference at lower speeds. The car is still louder than I'd like on the highway but much better than it was at point of sale.
I think the floor would benefit from some sound deadening. In this video
they've removed the carpet from the previous generation rav4. If anyone has any experience with removing that carpet I'd love to hear how to do it.
You would need to remove all body panels including the center console, as well as the seats and rails. Then you can unclip and lift the carpet exposing the metal floor. What stops most people is the taking out of the front seats. Once the seats are out, you could lay the deadening material pretty high up the firewall too. But it’s a whole lot of work.
2020 Toyota RAV4 XLE
Thanks for the ideas in this thread. I will be using Kilmat on the metal surfaces throughout. I like the idea of putting denim insulation behind the door and side plastic panels
and underneath the trunk floor mat. I think the denim could serve as a substitute for the closed cell foam. I'm thinking of adding mass vinyl in the spare tire and trunk wheel
well cavities since they are closer to the ground to further absorb road noise. Also, I may stuff the hollow, reinforcing metal structures with pieces of denim or a foam block.
2020 Toyota RAV4 XSE Hybrid (Blizzard Pearl/Midnight Black Metallic)
I like the idea of putting denim insulation behind the door and side plastic panels and underneath the trunk floor mat. I think the denim could serve as a substitute for the closed cell foam. Also, I may stuff the hollow, reinforcing metal structures with pieces of denim or a foam block.
I was think of that too when I read the ideas here. Then I became concerned about moisture that we get in the Pacific Northwet. Now, I’m thinking of fiberfill... https://www.ebay.com/itm/141960802013; 3M Thinsulate (TM) SM600L Acoustic Thermal Automotive Insulation for van and car | eBay
Denim behind the moisture barrier of the doors is not recommended. Should only be applied to the plastic trim panels. Keep in mind the 3M black side should face the inside of the cabin and the white fiber side is facing the exterior.
Here's a video of a guy who installed sound dampening material in the outside wheel well after taking off the protective plastic cover. His car is a Tesla but it could apply to a Rav4.
The relevant video begins at time index 7:00.
I bought this 45 sq ft denim insulation from Lowes. This giant bag in the hatch extends into the back seat and already quiets the rear of the Rav4 as is before its removal.
That wool is expensive and requires 100 sq ft to be purchased. I don't think wool's acoustic properties are any better than denim. Interesting information nonetheless.
🇨🇦 2020 RAV4 XLE Hybrid - Super White
interesting for sure, but my RAV4 doesn't deserve the wool cardigan treatment lol.
