Hello All!
This is my first post, so hopefully I'm in the right place. Thanks for any input. I'm the new owner of a '97 Rav4, 4WD auto transmission. I am hoping one of you can assist me in locating replacement hoses/tubes for the throttle body and idle air control valve. I haven't picked up a manual yet and don't know where to find a diagram. Mine are pretty brittle and I would like to get in there to clean the throttle body at least.
Should I just measure and find some silicone hose or am I better off buying OEM?
Thanks for any help, :D
-Andrew
Rockauto.com for many non-OEM parts.
And a hint while you are here -- to check the transfer case's fluid, the dipstick is in an odd place: down low, behind the right-front tire, almost horizontal. And the AWD transmission, separately, uses a special OEM fluid, not DEXRON.
1999 Toyota RAV4 with 3MZ-FE 6 cylinder engine, camo wrap, OME lift, heavily modded
