Having had to clean the throttle butterfly valve numerous times over the years, I was wondering if I should be removing the throttle position sensor and adding some silicone lube the other side too (presumably the "axle" passes all the way through into the sensor).
Anyone have idea of whether this is a good thing to do, or will the sensor not take kindly to being dismantled??
Thanks,
- Paul
Thanks,
- Paul
