1 - 1 of 1 Posts
I just put a trailer wiring harness in my XLE. Afterwards I noted the power rear door would not function.
Apparently, if you remove power and the door is open there is a ritual you have to go through to get it to work again:
1) disconnect the battery
2) manually close the door
3) reconnect the battery
4) start the car
The door should now work.
If you look carefully steps 2 and 3 are in the manual but "start the car" is not.
I assume this hold true if the fuse for the rear door goes as well ...
1 - 1 of 1 Posts
