1 - 10 of 10 Posts
Looking to install the Rough Country 2.5” lift on my 2019 XLE RAV4.
I wanna go 245/75/16 with the Toyo Open Country AT/III. As for the tire I read on a couple posts there is minimal rubbing with tires this big. My questions is can it be trimmed easily to get rid of the rubbing and if so could I go with even bigger tires possibly 255.
For the wheel I can’t seem to find info on the offset I need. I’m looking at all kinds of wheels and they all seem to vary on offsets so I am asking if this matters too much or if I should only be looking at wheels with a certain offset.
Thank you in advance if you take the time to read all this and help me out.
You can go as high as a +40mm up to a +15mm without modification. At 245/75/16 you're 0.7 inches wider so depending on your offset you may be rubbing at full lock in the front liner.
A 245/75R16 is a 30.5" tire. Speaking from experience, a +25 offset wheel will be around flush with the fenders. You will need to trim the lower valence at the front of the wheel well, but that is easy.
A 255/75R16 would be 31.1". My 30.5" with the above approximate specs only have about .25" of clearance at the rear of the wheel well, sk I would be hesitant advertising a 31"+ tire could fit without some not-insignificant trimming.
One correction: +25-+30 will be flush or a few cm outside of the fenders.
Any chance you could post a picture of the trimming you had to do?
Much appreciated. Looks like I’ve settled on 245/75/16 just struggling to find 16” wheels that I like because of the 5x4.5 bolt pattern.
2020 Rav4 TRD Offroad
There's a guy in Alberta running a 2.5" lift with 265/65R17 tires. He said they had to relocate the washer fluid container upwards slightly and trimming on the front.
That is a 30.5" tire also. Surprised it needed all that, unless the front lift was done with aftermarket coils rather than spacers. The spacers most of us run do limit up-travel for the front suspension.
Maybe because it is a wider tire? Not 100% sure on his offset either so maybe that factored in.
1 - 10 of 10 Posts
