Hi all,
I have a '16 Limited and it seems that there's no screen that tells you how much pressure is in each tire? I was surprised as my mother's '12 Camry has that feature. I can't believe I have to get out the old tire gauge and go hunting for the culprit that triggered the warning light.
Thanks!
Mike
I think that option was lost when the '15 model year came out, it's viewable using Techstream.
Is there no label on the door frame when you open the driver door, cold PSI is marked on the tires, and it should be in the owner's manual.
If one of the 4 wheels is not the culprit, it might be the spare that's low.
Does she have winter tires on rims without the proper sensors?
Ott.
The max psi on the sidewall of the tire is not the recommended pressure.
Best check the manual or tire site if tires are not stock.
