J
jj123
·Guest
Anyone know the consequences to this problem when I've driven it for close to 2 weeks at this pressure? And why would they inflate them so high in the first place? Any advice is appreciated
Geez, I just got mine and I never even checked. Its a Canadian model as well. Thanks for the heads up.jj123 said:Yes I used personal digital guage at cold temp. Each tire was exactly 52 psi.
If you do not have this system on Canadian RAV4's then you just had to reduce the pressure to normal levels.Press the valve core to reduce the tire inflation pressure rapidly by 6 psi (0.4 kgf/cm2, 40 kPa) or more within 30 seconds. If the tire inflation pressure is NOT reduced by 6 psi (0.4 kgf/cm2, 40 kPa) or more within 30 seconds, the tire pressure sensing transmitters will NOT be activated.
