Hey all,
my used RAV4 came equipped with an original removable tow hitch. To remove it, I need a small key but unfortunately I did not get it when I bought the car.
There might be a possibility to order a new key and it seems that there should be a serial number.
Could somebody help my find this serial number because I cant find it?
Thank you in advance.
Best regards,
Max
Hey all,
Best regards,
Max
Hey Max, congratulations on your purchase and welcome. As this is an aftermarket (although likely dealer-installed) accessory, there are very few ways to determine the key needed. Some locks will have a number or code on the lock face, but otherwise you may be looking at a locksmith or a grinder to cut the end off.
Anyone have different ideas?
As suggested the fastest way to remove it is with an angle grinder. Depending on the design a pipe can also be used to snap it.
Thank you very much foryota!
To me it seemed genuine but google showed me this picture and the design is very similar (but I have Toyota logo on it and not Witter)
It is quite rusty maybe that is why I did not manage to find it. I will try to get a clear view with some wd40.
Regards,
Max
Regards,
Max
Even if you do get a code, you’d then need to track down the manufacturer of the lockset and then see if they have a published resource for reproducing keys. I’ll warn you it may be a long road. It does look quite sturdy, so grinding might be a big challenge unless you attack the back side, but the other (simpler) option could actually be to replace the hitch...
Alternatively you may consider removing the hitch to take to a locksmith or garage to re-key or cut off the lock. That way they can work on it without tying up your new ride for a day. The last item to consider is the cost for the work (if you can’t do it yourself) vs the cost of a replacement hitch and drawbar - 1 hour of shop time may approach the price of a used hitch.
Reactions: ravenuer
