HI everybody ! I have a TOYOTA RAV4 2007. it crank but won't start i check all fuses, change battery still unable to start .do you have any Idea that can solve this please .
It could be a bad starter. You can get someone to tap the starter lightly with a hammer while you start the car. Sometimes the brushes in the starter is worn and this may move the brushes just enough for the car to start. Another possibility is a bad alternator which you can test with a volt meter.
If it keeps cranking, that means the starter is fine... I'm leaning more towards a fuel related problem, bad fuel pump, bad MAF sensor... do you have any way to see if a CEL code is stored??
Also, being a 2.4L 4cyl, make sure there's actual oil in the motor... you could be cranking a dead motor.
It may be an immobilizer problem. Is there a red "Security" light on the dash near the A/C controls? If that light is flashing, the RAV will crank but not start. There is a chip inside the key that should make that Security light go out when the key is inserted. The chip in the key must be programmed to the car.
@Herdj glad you could figure it out... had the same issue with my Corolla last year, died on me on new year's eve... fuel pump was dead, the car just kept cranking over and over.
Related Threads
Toyota RAV4 Forums
993.1K posts
147.4K members
Since 2004
Rav 4 World is the internet's largest Toyota Rav4 SUV and EV online forum community. Discuss towing, modifications, and more.
