R
rav4_at
·Guest
It appears that toyota has seen the light and put the viscous centre diff back into the latest Lexus RX. The technican at the dealership told me that they found out the viscous on the Earlier model RX and RAV's works much better than the electronic version so they went back.
A case of dont fix it if it is not broke
"The RX 350 has a new five-speed automatic transmission equipped with an integrated transfer case and a new viscous-coupling-controlled, limited slip differential, replacing the previously all-electronic centre differential. Normally, torque is split 50/50 between the front and rear axles, but under slippery conditions, the limited slip differential directs more power to the axle with the most traction"
