1 - 15 of 15 Posts
Pahoo
RAV4 Hybrid 4x4 AVA44
Discussion starter · #1 ·
Has anybody ever had a dead TPMS sensor on his RAV4 Hybrid (2017) due to low battery and if yes, after how many years and miles (or km) did that happen.
I'm especially interested in the lifespan of the original Toyota sensors, that were mounted in the factory.
don't know about your 2017 specifically w/o part number
but my 2013 (now 11+ years old) Tacoma sensors work fine today
it is common for them (toyota sensors) to go 14 years or more
it is uncommon for them to fail before 10 years
lifetime also as has to do with mileage as they go to sleep when vehicle
is stationary, and wake up when wheels rotate. so if you put on serious
miles they may have a shorter life but still they last a long time... and a 2017
shouldn't be dying now, but take mileage into account
Discussion starter · #3 · (Edited)
Thanks for sharing your experience.
My summer tires need to be replaced after about 45.000 km an 7 years and I'm uncertain, wether to use the opportunity to also renew the sensors.
But I guess I take the risk and will not replace them now.
I have taken pictures in 2017, the sensors look like this:
My son has a 2007 RAV4 with the original sensors (17+ years). The only time I’ve had a sensor go bad on one of my cars (various makes) is after a tire change or flat repair. I think some tire service people drop them on the ground, toss them or something while the tire is off the rim. I have no other guess for the coincidence.
Hello engineers, can someone please invent sensors with inductive charging?!
You would still need a battery in the sensor to charge. Why add the charger, which could also go bad. Instead of one failure point, you now have two.
Discussion starter · #13 ·
Well, yes. I'm an engineer myself and can't think of a way how that could be done elegantly.
Why add the charger? It would safe many sensors, that are good for a couple of more years, to be replaced precautionarily.
1 - 15 of 15 Posts
