Hi all!
I recently became the owner of a new 2017 RAV4 Hybrid Limited!
Unfortunately, I'm a bit puzzled about the ToyotaEntune app on my iPhone. I've installed it, and it seems to launch every time I hop in the vehicle, but I don't really understand what it does, or why I should even use it.
Could someone please help me understand what the ToyotaEntune app does, and why I should use it (or not)?
Thank you!
np
I think of it more of a "proxy" or "gateway" app for the Entune head unit to be able to access traffic data and apps like Pandora, iHeartRadio, Slacker, etc. The head unit uses the app over Bluetooth to then talk to the Pandora, etc app on your phone to control it.
If you do not use online streaming like Pandora, you do not need it.
When you install Entune apo on your phobe and first time sync bluetooth, it will "update" apps on headunit. This is not the firmware update. Just the apps. You will see more icons on headunit.
To remove icons, you can delete personal settings. It will remove everything you customized.
Sent from my HTC One M9 using Tapatalk
Drpepeprz: Yes.
You will need 2 accounts. One for Entune and one for Spotify.
All controls work. Make sure you have unlimited cell data plan or keep an eye on you data.
Check the owner's manual.
