I did a search. Didn't fine much.
2010 v6 Ltd with 4wd. Sitting stopped at a light, dry ground, the traction control light and audible tone comes on briefly. The. Goes off. Light changes, car has a littl brief lag before power comes back (basically it won't roll at idle power like it normally would).
Thoughts?
Thoughts?
Your Googling skills need work LOL...that is the hill start assist...at a stop when you firmly press the brake you are activating the system...the noise and flashing light are to let you know it's activated...it will hold the brakes locked long enough to let your foot move from the brake to the gas...I do believe it is talked about in your owner's manual...
