1 - 8 of 8 Posts
Model: 2010 RAV4 V6 Sport
I've been looking into adding a trailer for a while now, already have the hitch I installed last year but don't have the wiring. I wired my dad's Tacoma last year and it was easy as just plugging in 3 connectors and dropping them out the bottom.
I've been looking into doing this on my RAV4 and the process seems a lot different. It want's me to run a long wire to my battery???? It just seems over complicated, is there a super easy plug and play option? I don't mind spending the few more $$$
thanks
If you have a 12V outlet in the back you could tap into that for the converter power instead of running wire to the battery.
There is this video from etrailer.com :
I do have one! So rather than tap into battery, just tap into the positive on that? Genius!
Thanks!
Keep in mind that that rear outlet isn't live power so lights you may want on with the key off like the 4-way flashers may not work. That didn't concern me so I used it.
Also it's only power enough for trailer brake & signal lights and not for heavier usage such as the 12V loads of a camper.
Just run power wire from the battery. I ran mine from the back under the plastic covers in the door sills and through a grommet under the dash that came out behind the strut tower to the battery. Don't take shortcuts because it's really not that hard.
Yes, the wiring harness I purchased supplied all necessary connections and a fuse.
1 - 8 of 8 Posts
