1 - 2 of 2 Posts
im working on a 2009 rav4 , 4wd , i have a leak , its gear oil and it seems to be coming from the transfer case where the drive shaft bolts to. Now i thought it would be a simple fix , you know unbolt the drive shaft from the rear end , pull a yoke out and swap out a seal , but hell no , seems like you have to pull 5 bolts and out comes a pinion gear , anyone have this leak ? , know if i can replace the seals ? , or do i have to replace the entire penion assembly ?????????
1 - 2 of 2 Posts
