G'day all,
I've got an automatic RAV4 2006 2.4l, 4Cyl I've owned and driven since 2016. Purchased when it had around 216,000 kms on it and not currently sitting at 226,000 kms.
I've been replacing the oil myself and would now like to attempt a transmission fluid drain and refill. However, for the past year I've had an issue when when on a slope or if under a bit of load the car has started to slip on reverse. Doesn't happen always - but it does.
My first thoughts are - Would the slippage get worse on reverse? Should I even attempt a trans fluid drain and fill?
Thanks for any help
Jake
Thanks for any help
Jake
