Fluid in my 2010 Rav 4 Sport automatic is a little toasty and slightly brown. All works well, so I was going to change the filter and replace transmission oil. Guy at the dealer suggested to leave the filter alone, says it basically is just a metal screen, but to dump and refill with fresh fluid. Vehicle has 85000 miles on it approximately. Manual says service isn't required. Anyone with ideas and opinions?
Moved to 4.3 forum
Good idea to drain and refill fluid. Usually takes a little over 4 litres. The filter is a metal screen which doesn't need to be changed. Some people buy aftermarket kits and change it anyways ??
Do a drain a refill now, then another
one in a few months. Then you should have the majority of the old fluid out.
2007 Rav4 Sport V6
I just picked up the fluid yesterday from the dealer to empty/refill. Will not be changing the filter. transmissions are sealed there would not be enough dirt collected in the filter to ever necessitate changing it.
All the 4 cylinder models have the reusable metal mesh screen filter. The V6 has the paper filter. By the way that factory metal screen filter is over $50 not including the o-ring and gasket which is sold seperately. You probably did not read the Owner's Manual Supplement which does say you need to change the ATF every 72 months/96,000km which every comes first. If you operate your vehicle: short trips less than 5km, tow a trailer, drive in dusty or muddy road, and drive frequent mountainous driving you change ATF every 24 months/32,000 km.
