hey guys i am new to this forum . Can any one help me with the 2002 RAV4 with a 1az-fse engine trouble code P1653 ? when ever the cel come on the transmission will not go into OD
Welcome!
P1653 SCV Circuit Malfunction / 58
This could be caused by the oil control valve, low oil level, infrequent oil changes, a fault in the wiring to the valve or a bad PCM.
What is odd is that the code is not listed in my information database. I consulted the oracle (Google) and was able to find this :
https://obdii.pro/en/code/P1653
The transmission will not go into overdrive because the PCM has detected a fault. Some Subarus will disable the cruise control when there is a fault code stored.
