Hi all
I just checked my rav for trouble codes today after doing a fair bit of work over the last month. I just need confirmation that I diagnosed the codes right as I have not done this before.
I got 2 flashes - pause - 1 flash - pause - 2 flashes - pause - 2 flashes - pause - 2 flashes - pause - 5 flashes - 5 sec pause.
I have worked this out as code 21, code 22 and code 25, am I right? There was no CEL lit and never has been in the 3 years (2000 miles) I have owned it so would these be old codes in the ecu?
I have renewed the 02 sensor and the coolant sensor before this but have only done about 100 miles since fitting , the other code 25 is for lean mix according to the fault code sheet I have downloaded?
Any help greatly appreciated
regards
Kevin
regards
Kevin
