1 - 12 of 12 Posts
Toyota's Urban Cruiser Concept @ Jalopnik
Hideous as some of the details may be on this creature, you can definitely see the lines of the newest RAV4 all over the place -- especially above the beltline.
Could it be that Toyota has more in store for the RAV4's platform? Exciting part is that it's shorter and only has two doors!!!
G
There will be smaller suv based on yaris, in 2007, at least in europe...
It would make sense if it is based on Rush though...
It kinda reminds me of a mixed between the Nissan Murano, a Beetle and the PT Cruiser :x ewww.
Scott Cummings said:
It's actually got 4 Doors this Toyota Concept if you look closely, The rear door handle is hidden into the body. Click this link below for the full size version and you can clearly see the rear door handle (well hidden) and the door line for the rear door.
If it is a door, then it's could be a suicide door. But it really looks like seam. Similar to the one that's on the front fender in line with the bottom of the front headlight.
Discussion Starter · #11 ·
Scott's talking about this little detail along the vertical line at the back of the vehicle. It does indeed look like there could be a small spring-loaded panel designed to hide the door handle. If so, it's still hinged like a normal car door.
Discussion Starter · #12 ·
Quite belatedly, here are some more photos of the Urban Cruiser -- rear door seams and handle panel are much more visible despite being low res.
1 - 12 of 12 Posts
