So - my wife is driving and the ABS & Brake lights illuminate; she tries to engage cruise and only gets a flashing light. Tells me this happened one other time - an intermittent problem. I put a scan tool on it and get the above codes - with the P1578 code appearing twice. Research shows that the U0073 is 'ECM Mod Bus Off' and the P1578 is either a 'brake booster vacuum sensor' or 'yaw rate sensor' malfunction. The cruise is throwing me for a loop, but I'm guessing it won't engage if there's some sort of detected problem in the VSC system.
My limited research seems to point to maybe three things:
1. Defective brake light switch
2. Defective VSC computer
3. Defective sensor (yaw rate, ABS or someother - take your pick) or connection
Looking for suggestions, since a VSC computer might easily be the most expensive issue and the brake light switch the least expensive. Tracking down a loose connection under that hood or under the car might be the nightmare.
Is the RAV4 set up for towing?
No, it is not.
Wondering about this: Could it be an intermittment failure of the ABS module? I know there are a lot of folks who get codes from bad electrical connections...I'll probalby take off each wheel and check the ABS harness & sensor...I'm pretty sure the P1578 code was not a brake booster but more of an ABS fault...low voltage somewhere...
