1 - 8 of 8 Posts
Now i'm getting a little crazy with my newly purchased 2008 limited Rav.
I'm envious of everyone's updated antennas.
It's the only eyesore (in my eyes).
So has anyone found a nice replacement stubby? I saw some older posts, one was for a harley davidson antenna that worked well.
I'm thinking of even removing all together, and was curious if anyone has done that and just found a good cover to put on it, like the below link.
Any advice?
http://www.amazon.com/Larson-Antenna-Plastic-Hole-Plug/dp/B0049D7GBU
fender?
not following, wouldn't that be a big deal to replace?
the antenna is on the edge of the hood.
2006-2008 the antenna is mounted on the passenger side fender...you can get a used fender from a 2009-2012 and it will bolt right up...you would then need to figure out what kind of antenna to use and where to mount it...
Just replace the fender with one from a 2009...I agree that the antenna on the fender blows...
Not great with car work,
Wouldn't that be pretty expensive? Especially if I am dealing with a limited Everglades metallic color?
Is there another route that is less expensive or easier for a fix?
You can search on eBay for a fender of the same color...also you can search car-part.com for a fender of the same color...replacing the fender is only way to make it nice and clean...if not doing that I would just leave it alone...
I just unscrewed my antenna and screwed in a stubby one I bought online.
The threads are standardized.
Yes, I lost some low signal reception, but for less than $20 US it was well worth it.
1 - 8 of 8 Posts
