1 - 16 of 16 Posts
C
Is it the standard Toyota regular is recommended, but premium should be used for "optimum performance" or something, or is it regular all the way around?
Unless you're in a turbo Supra or a GTS Celica or something that requires higher octane, regular.
If the manual says 87, use 87. Read my post in "What grade of fuel do you use?" My fingers are sore after posting that one!
OC :roll:
Octane at altitude??
Our regular here in Colorado is 85, mid is 87 and premium is 91. Would I use 85 or 87??
The 06 RAV4 V6 actually have a higher compression ratio than the 05 Celica GTS. The RAV is 10.8:1 and the Celica is 10:1, therefore, the RAV may be able to gain more horsepower from premium fuel than the Celica.
C
Actually, my V6 Camry says 87 minimum, or 91 for optimum performance. I run 91.
In Colorado, you should be OK using 85. I forget the exact arguments for it, but it should be safe for the engine. However, if it were me, I'd run 87.
The GTS has a compression ratio of 11.5:1 and requires 91 octane. Otherwise the computer is working overtime to prevent pinging.
The GT, which requires 86 octane is what is 10:1
S
You would be hard pressed to notice 3-5 horse power, unless of course you were being drug around by 3-5 horses! :lol:
1 - 16 of 16 Posts
