1 - 2 of 2 Posts
N
2AZ-FE engine (and maybe others?):
Apparently, the metal valve cover oil baffle is prone to breaking loose when any metal oil filler spout is jammed in there when filling with oil during an oil change, can you say Iffy Lube? If you look in the filler hole, it covers approximately half of the right side of the oil filler hole. If a piece of it breaks off, say goodbye to your valves, as it will jam them up. There has been a TSB on this very subject, BEWARE!
Check out RAV4WORLD TSB's .....
Thanks Jeff
1 - 2 of 2 Posts
