Noticed a vibration, when the car is in REVERSE or when the car is stopped at stop light.
So far,
Changed transmission fluid.
Replaced Front, Driver, Passenger side transmission.
But, could not remove rear (transmission) mount. The sliding bolt in rear transmission mount was impossible to take it out (Picture is added). Have anyone replaced the rear (transmission) motor mount?
Anyway the vibration was reduced, after changed the mounts. However, still having a small vibration problem.
I do not see rpm fluctuation when it is in idle or in gear.
Does anyone have any clue?
Thanks
Year, model & engine please.
RAV4 2007 2WD AUTO 4 CIL
Hi! I have this same problem. Did you found what was the cause? Best Regards
Same 2007 RAV4 Base I4 (2.4L)
The last time the OP was signed into the forum was 2017 so I doubt you’ll get a reply from him. His first post said he had a lot less vibration after replacing some of the mounts. Having said that, there are SO many things that can cause a vibration, I would investigate further before throwing parts at it.
2012 RAV4 Base FWD.
Upgraded to large from brakes and 3rd row rear springs.
Reactions: NesMora0518
