I've been having this issue for almost 2 years now. I filed a complaint with the NHTSA but nothing ever became of it. I noticed that other Toyota models may be affected by the same issue.
You might try turning your wheels straight ahead on a level surface and then disconnect the battery for at least a minute, this can reset the baseline for the yaw sensor.
Baseline has been cleared several times already via techstream. I replaced front strut/springs and rear shocks along with all 4 sway bar end links and performed a 4 wheel alignment. The VSC still kicks in intermittently on the highway. I have new front ball-joints and a rebuilt steering rack with inner and outer tie-rods that need to go in next. Hopefully this cures the dreaded VSC issue. I'm sure front control arm bushings are probably tired as well but one thing at a time.
Related Threads
Toyota RAV4 Forums
993.1K posts
147.9K members
Since 2004
