1 - 10 of 10 Posts
Why would the VSC/TRAC and Check Engine lights be on?
We took it to O' Reilly Auto Parts, and they said it may have a leak somewhere around the lines that go to the gas tank. It had something to do with the evaporation system, I believe. They didn't know why the VSC/TRAC light was on.
It said "Oops... Network error, refresh to retry. I don't seem to have a problem with my Wi-Fi network at this time.
- Jesse Williams
The link works fine for me.
Happened to my 4runner and my lexus. It was the O2 sensor. I know, stupid right?
But I pulled the codes and googled them and that's what I came up with.
I swapped the sensor and the lights were gone...
Happened on mine I disconnected the battery hasn't come back on in 2 months. If you do this your car will idle like crap and shift funny until it relearns the settings. I do this on all my vehicles sometimes computers make mistakes.
4.2 (as well as other models) a CEL will command a VSC/TRAC as well.
Similarly, an ABS fault will also trigger VSC/TRAC
Fix the issue causing the CEL and the rest should clear.
Bad cat will also trigger the VSC/TRAC (P0420, P0430) . Happened to mine, hooked up the OBDII and showed cat was going bad. Reset and was good for about a year, then started to come back. I got tired of resetting the codes and replaced the cat, been good since then.
Reactions: tarjeta
1 - 10 of 10 Posts
