1 - 17 of 17 Posts
So I am wanting to get new wheels and I absolutely love the look of the new Subaru wheels... does anyone know if the forester wheels will fit on a 16 RAV?
Forester wheel info:
– Center Bore: 56.1 mm
– Lug Size: M12 x 1.25
– Wheel Fasteners: Lug nuts
– Trim Production: [2014 .. 2016]
225/60R17 98H 7Jx17 ET48 5x100
225/55R18 98H 7.5Jx18 ET48 5x100
Rav4:
– Center Bore: 60.1 mm
– Lug Size: M12 x 1.5
– Trim Production: [2016 .. 2017]
225/65R17 102H 6.5Jx17 ET45 5x114.3
225/65R17 102H 7Jx17 ET45 5x114.3
235/55R18 100H 7.5Jx18 ET45 5x114.3
Bore, Offset and bolt pattern are all different.
I'm also wanting to put new wheels.
I want to try 10" wide rims. I don't know how the car will handle though.
was thinking of running 19x10"s. I didn't see anyone else running that size so I'm not exactly sure how the fitment would be. Don't want to run into rubbing issues with the stock strut (planning 285/45/19)...
may just spring for 19x8.5"s :serious
Why don’t you go aftermarket?
What're the fitment details on those sweet wheels please? I'm looking to go aftermarket as well. I want to go 17x8" +35 offset on the stock 225/65/17 tires but I'm not sure if that will clear (suspension, strut etc.) as compared to the stock fitment (17x6.5 +39) *I'm in Australia by the way.
Mine’s 17x7.5 with a 45 offset. Im pretty sure a 35 offset wouldn’t be an issue as there’s still a lot of clearance with the liner and the calipers. About the width though, check the wheel specs. If it says it can fit a 225/65/17 tire then ur good
I just ordered a set of MB Optima wheels and Nokian Hattapeliitta 7 winter tires for my new RAV4. The wheels are 17 x 7.5 40mm offset with 225/65R17 winter tires. I bought them from Discount Tire with tire sensors, road hazard warranty, mounted and balanced. The entire package cost $1205 out the door with sales tax and I got $320 worth of rebates for a net price of $885, not bad at all in my book.
Here are the wheels I bought.
Those are the same wheels I put on my sienna with blizzacks. Starting to corrode at the center caps but been good wheels otherwise.
Sent from my SM-G900V using Tapatalk
1 - 17 of 17 Posts
