1 - 2 of 2 Posts
Read Only
A couple weeks after I bought my '05 we had some good rains. One of the headlights has a lot of water beading inside it. Is there an easy DIY fix? Several years ago I had another car that actually collected water in the headlight. I simply drilled a small hole at the bottom of the lens cover. Everything drained out and that was the end of that problem.
I've used the same small hole trick on several headlights. Always works perfect. I think the heat from the bulb forces the moisture out as much as it drains out. In any case it works.
Reactions: 358905
1 - 2 of 2 Posts
