I know that there are many posts about the water pump and I have read through them but can anyone tell me if the new replacement water pumps that Toyota uses are any better than the original? In other words, will I have the same problem with it going bad?
Thanks,
2010 Rav V6
That's a good question. My original water pump got noisy at a little over 42,000 miles. They replaced it with the new and improved version. But, since I've only done a little over 3000 miles since then, it's a little early to know if it will last longer.
Mine was "weeping" for a while and the coolant level was slowly dropping. The "weeping" stopped about a month ago and the coolant level is staying at max. I check the level weekly just to be sure it doesn't start "weeping" again.:crying
When I did a search covering Toyota parts suppliers a few years ago regarding the 4.3 coolant pump there were two different part numbers given. I suspected that the later pump was a revised model. Unfortunately I don't have those parts numbers now. I had to run through multiple suppliers' listings to find the one which listed the different numbers.
Often times a new REVISED Toyota part will have an R in the part number.
