21 - 30 of 30 Posts
Any plans to sell them or release the file?
Edit: is that thing solid?
My solution so far (which works fine) is a 9"x6"x4" "yoga block" from Amazon. Had to take a sharp chef's knife and shave about 1/4" off of it to make it 3.75" thick; then it fits perfectly on top of the foam that the factory jack sits in.
I can send you the STL file for 3D printing. It´s not solid. Only 10 % infill, but 2 mm. shells all over.
ThomasDK, that is a good design, but you appear to not have a spare tire so your tray is different then the U.S version. The U.S. version has the tow hook in a bag and the foam piece you're using a rib of is not there. The U.S. version has the scissor jack in the area you prop would fit.
I borrowed a picture from another thread. Disregard the red and black wire.
As you can see, the U.S. version has a spare tire and a jack in the center. The foam is configured differently so your support post wouldn't work in the U.S.
154702
Reactions: ThomasDK
Jezz people... Put some tools, air compressor, emergency blanket, or even your entire collection of resuable shopping bags in there, it fills up fast. This is the one thing I don't like about the new rav4 (coming from a gen 3)
slightly off-topic, is that an Anderson plug for an inverter I see?
Like I stated, I borrowed the image from another post which was related to an inverter connection so I wouldn't know.
You could ask piyoman in the following thread. Thank you piyoman for the use of your image.
I just used a chunk of 2x4 that was in my scrap pile.....the wedge shape was accidental but beneficial that it fit tighter. It supports my 220#.
155182
I just used a chunk of 2x4 that was in my scrap pile.....the wedge shape was accidental but beneficial that it fit tighter. It supports my 220#. View attachment 155182 View attachment 155182
I was going to say, 3D printing some custom block, or shaving down a block of foam all seems like overkill. A 2x4, a circular saw, and a few minutes seems like all it would take to me.
There is nothing more satisfying than overkill. I have the opportunity to draw and print myself, so of course I choose that option over unnecessary weight of wood in the trunk.
21 - 30 of 30 Posts
