1 - 8 of 8 Posts
Hi. With the factory roof rack weight limit being 102lbs, is that the result of it's attachment to the vehicle being weak, or the rack itself being weak?
Does an aftermarket rack make the weight limit somewhat of a non-issue, with the weight limit becoming that of the rack?
Out another way, is the limit the vehicle or the rack?
Yakima's rack weight limit for what I want is 250lbs, which is beyond the 170lbs I need.
Ask Toyota where the limit lies. No one here designed it so we've no idea. Either way it sounds like you plan to overload it.
Remember, these weight limits were imposed by lawyers, not engineers. You will find the limits and capacities much greater for the same vehicle in Europe and other regions.
I know we far exceeded 100lbs with a full Sears X-Cargo XL roof carrier on our cross country move. Aside from some scratches on the crossbars it held up fine.
You can just replace the cross bars with the Yakima ones. I was looking at a rooftop tent made by Yakima. They specifically test and certify different vehicles. That tent setup is close to 200 pounds. I think they rated the gen 3 rav to allow use of the tent plus 400 pounds of human weight in the two person tent. This was only after replacing the cross bars and cross bar mounts ( I think they call them "towers") with the Yakima parts.. The main base rails from the factory that run from the front to back of the rav remain in place.
Keep in mind that if you have extra weight on top, you're drastically altering your vertical centre of gravity, making your RAV more prone to leaning in turns or emergency evasive maneuvers. JuneBug is right about the lawyers, but in this case with the rotational moment, I think the engineers would have had some input. Good luck and enjoy!
Reactions: packmule
Hi. Did you ever get the answer to your question? What did you end up doing? I'm having the same dilemma. I purchased a Thule cargo carrier and it weights 42 lbs and the max load on the 2011 Rav 4 sport is 102lbs. Which leaves me with 60lbs to work with inside the carrier. I was wondering the same if it's the roof or the rack system that can't handle more weight. I have search everywhere and nobody can give me a definitive answer on this. Thanks.
1 - 8 of 8 Posts
