Where did you get those mirrors?
Open the driver door and you'll see a seam where the plastic panel meets the one further into the dash. I worked a plastic trim tool into that seam and gently pried it open until I could get a decent grip on the door side and from underneath the steering column, then just firmly (and carefully) pulled it towards the seat. There were 3-4 clips that will pop out and release the top for a workspace, and it will clip back together when you're done.I’ve been wanting to do this too. Did you pry the panel out from the front or do you push it out from the back somehow? And thanks for the Dremel tip. Why did they have to key them? Ugh.
Nice. What's the ground clearance with that? Mind posting a link to it?
Hopefully not Montreal. It would be on a boat by now.Mine is sitting airport parking lot, while I am on holiday.
Looking Good, time for some snow Fun...Over past few months:
LP Aventure Lift kit
LP Aventure LP1 wheels
Falken Wildpeak 255/65/70 (required slight trimming of front fender liner/mud flap)
Fitcam X front dash camera
Kicker dash speakers
OEM receiver hitch
OEM black exhaust tips
Taco Vinyl hood stamp
View attachment 191687 View attachment 191688
Which paint did you specifically use? This looks awesome! I'd rather not pay $$$ for new wheels yet.This are the wheel covers to go with your wraped roof. Painted with Bedliner spray. View attachment 153768 View attachment 153769
If you colored the car rims like the bike, that would look sharp, and less commonplace. Not the spokes or center part, just the rim. I know some call the entire wheel the rim, but I mean like the bike, the outer section.
Wheels OEM to bike (a/k/a not my choice). A smidge above commonplace is my sweet spot.If you colored the car rims like the bike, that would look sharp, and less commonplace. Not the spokes or center part, just the rim. I know some call the entire wheel the rim, but I mean like the bike, the outer section.
Many Toyotas use general wire harnesses that come prewired for optional features, just the other end of the harness is missing the specific gizmo/relays etc.I found this shoved into one of the blanks...no idea what it does. I have the cold weather pack and no power liftgate; anyone know what it might be? There are two blanks so what options am I missing in this area that it might control? If I can get an extra feature for the cost of a switch I'd probably do it. Ejector seat maybe? Ludicrous Speed?
Hey, do you happen to have a picture of where you trimmed to prevent the rubbing and how much of it trimmed off?Over past few months:
OEM receiver hitch
Front liner trimmed less than ½". Dremel works well to contour the cut (not a straight cut across).Hey, do you happen to have a picture of where you trimmed to prevent the rubbing and how much of it trimmed off?
It looks great that way, but it was designed to use the 4 bottom hooks. It lays flat on the floor and you can put your grocery bags under it or stuff in between the envelope of the net. Either way I may use it like this sometimes too now. Thanks for sharingI installed the Gen 4 RAV4's OEM cargo net since Toyota only makes spider net for 5th gen. It fits perfectly, but you'll need to use carabiners, zip ties or any clip in order to secure the upper loops. You can only install it behind the rear seats, if you want to install it at the opening of the cargo hatch you'll have to drill holes and install screw-in hooks since Toyota didn't include the tie-downs on top.
I think that's this one, I couldn't find an envelope style for the 5th Gen, only this spider net.It looks great that way, but it was designed to use the 4 bottom hooks. It lays flat on the floor and you can put your grocery bags under it or stuff in between the envelope of the net. Either way I may use it like this sometimes too now. Thanks for sharing![]()
