2221 - 2240 of 2275 Posts
Today I upgraded those cheap plastic knobs on my 7" screen to match the big rubberized climate control knobs. Ordered them from Toptoyotaparts.ca They came in at $50 after shipping and taxes and were back-ordered for 3 weeks. But a good improvement for sure.
Oh wow, that’s awesome! I think I’m going to order these right now- is it exactly as straight forward as I assume? Just pull off cheap OEM ones and pop on replacements? No fitment issues?
Which blank did you unplug that from? If it was the far right one, it is for the power back door, if it was the blank near the middle it is for the birds eye camera.
I'd wager this must have been for the power back door then, but I can't remember where it was before. In the PNW most Ravs come with the cold weather and convenience packs, but I'm not a sunroof guy and I didn't want the extra failure points of more motors and whatnot so I ordered without that. I reckon you're right and that they use one common wire harness for that build.
21 RAV4 XLE Premium AWD Gas
Changed differential, trans and transfer case. 2021 XLE 40K.
Sounds like we have the same car...
Im at 25,000 miles, just did the oil change last night.
Im gonna do the same as you from 30 to 50,000 miles.
Did you do it at home, jack stands...?
What fluid did you use,...?
What condition was your fluids...?
To change the oil n filter, i did not have to raise the car at all. it was tight though.
Good job on all that,
i must admit the oil change took me longer than i thought it would, after all i had to crawl back under there, check for leaks, then put the cover back on.
Changed the oil n Filter with Toyota Filter & Crush washer, By the way the washer did not come off with the drain plug, it was stuck so much i had to use a knife to get it off, Careful... 0W18 Mobil One....
Also put the rubber Hood Seals on the sides of the light's to hood gap.
Checked the Air Filter, it had a lot of loose dirt in the filter but still clean.
Installed a leather steering wheel wrap, and some trim pieces to the interior in certain areas. May not be everyone’s cup of tea but I wanted the plain, drab interior to have some dimension and contrast. The upper door trim pieces and speaker surrounds are real aluminum too, I was surprised at how nice the pieces are. Saying I love the result would be an understatement lol.
Vehicle Car Speedometer Motor vehicle Plant
Automotive tire Automotive lighting Automotive design Grille Carbon
Speedometer Car Vehicle Gear shift Motor vehicle
Gear shift Car Vehicle Radio Satellite radio
Mirror Light Car Vehicle Automotive design
Automotive parking light Vehicle Automotive lighting Automotive tire Hood
Automotive parking light Vehicle Automotive tire Automotive lighting Grille
Motor vehicle Automotive tire Automotive design Automotive lighting Vehicle door
Vehicle Car Gear shift Motor vehicle Automotive design
