The Toyota Care 2yr / 25,000 mile states they will inspect & adjust fluid levels. Which fluids do they inspect?
Oil, brakes, windshield washer reservoir, coolant. I seriously doubt they ever check the auto trans because of the lengthy procedure involved.
Thanks for the info. Was curious if the transmission fluid would be checked and fluid in the trans axles. I know these are sealed units and usually don't need to be checked. They also say the transmission fluid never needs changing but I disagree.
Thanks for the info. Was curious if the transmission fluid would be checked and fluid in the rear differential and transfer case. I know these are sealed units and usually don't need to be checked. They also say the transmission fluid never needs changing but I disagree.
