That website should be used more as a general rule, rather than specific, as I don't believe it has exact measurements of things like tie rod ends, calipers, struts, etc, for each vehicle. You are correct, +45mm will push the hub further to the outside of the wheel (further from center 0mm), and will bring the rim closer to the suspension, brakes, etc.Just as a FYI......my 2015 XLE alloys are 17X7 with the 39mm offset. Last night I test fitted my alloys from my 2005 Chili Ed. (Sport in USA) which are 16X7 with a 45mm offset, on the LF. There seemed to be good clearance between the calipher and the alloy, and the tire and the strut. Picked up 4 General Altimax Arctics 225(70)X16 because they were highly thought of by some on here:wink and because they were on sale at CTC. Went with 225 instead of the normal 215, so the size would be closer to my 2015's 225(65)X17.
The 16 alloys were summer wheels on my '05 and '12 RAVs and have never seen salt.....till now:crying.....
I was a little concerned as the website above shows 40mm as the max offset for the 16X7s I have.... Am I right in thinking the 45mm c/l fits farther inboard??
