1 - 1 of 1 Posts
Not sure if i am getting it right haha.. maybe someone can correct me..
For 2017 RAV4 XLE 4AWD I purchased:
4 32mm 5x114.3 Hubcentric Wheel Spacers with 12x1.5 Studs, 60.1mm bore by Precision European Motorwerks. That should work with the stock hub perfectly. (I hope)
4 New wheels specs are 17x7.5 5x114.3 60.1mm bore. With 6.01" Backspacing and +45mm offset.
Stock wheels specs are 17x7 - 5x114.3 60.1mm bore. With 6.01" Backspacing and +35mm offset
To compensate wider wheel (12mm wider) it has bigger positive offset +10mm over stock offset, while it really needs only 6mm to cover it (if i am not mistaken, backspacing is the same) So it`s eating away about 4mm from the wheel going outward offset wise, which will be compensated by spacer.. So if my approach is correct, actual going outward will be roughly 28mm? Or i lost it somewhere in the middle of my calculations :surprise:D
1 - 1 of 1 Posts
