Wheel spacers, anyone?
616 Views 6 Replies 4 Participants Last post by  totoyotata
5
For those of you who don't know. wheel spacers are a cool, albeit nearly useless accessory for any car, truck, and SUV. It's use case is almost entirely aesthetic in nature. With other uses being things like making up for the offset you miscalculated on your supra.
That being said, in dropped some moolah on a set of 1.25" spacers from Titan Wheel Accessories. (Yes they actually have them for the first gen. thanks titan, for thinking of us)
Why would I buy something I covet as useless? Well, like I said... They're cool. And will make up the offset from the rims I took of a Santa Fe V6 I used to thrash around the dirt circuits in Minnesota. So they're gonna stay on until I can afford actual wheels, or a lift kit, or... Something. Not sure.
Without further ado. Here it is in all it's uh, glory.
Automotive parking light Tire Wheel Car Vehicle
^ not on, lame
Tire Car Automotive parking light Wheel Land vehicle
^installed, instant 50 horsepower
Automotive tire Grey Gas Art Circle
Automotive tire Silver Alloy wheel Body jewelry Rim
^initial unwrapping an inspection, the coating was good. no scratches, dings or dents. The lugs and bolts are well fit and heavily plated it seems.
Tire Wheel Automotive tire Tread Synthetic rubber
^ the fit around the hub is immaculate, it's almost like they even took the rust into consideration. These are hub centric as you may have noticed, 60.1mm
OUTTAKE:
installation was a bit annoying when starting out. The lug wells were exactly the diameter of the socket I was using, which was annoying because it would get stuck and torque values would be inaccurate. Found a 19mm socket with a smaller OD and everything was a breeze afterwards.
After fitting all four, I was pleased to see I picked the right size. The tires line exactly up to the edge of the fender, no farther. I know alot of people like to stick em out a bit farther, but in the hanging nutsack of Canada we proudly call Minnesota, we can't do that. Not that it stops those ram owners.
Off the jacks, I ventured to drive it up 22 for 10 miles and back thereabouts. Everything was dandy. No vibration, no cachunkin'. Stiff as a board. Perfect. Handles just as well as without, though it does feel notably different. Good different, though.
Only con I can think of is that even before the installation, my tires which are 2 inches too tall were grinding into my wiper fluid tank, and now it's worse. But that's not it's fault, it's mine. And I'm replacing and relocating the resivoir and pumps to where the battery is anyway, and the battery is going in the right side tool box. So I can connect camping equipment to in from the hatch.
Other than that, just the rear studs are a might bit shorter than optimal. I'll be avoiding pot holes and driving like a maniac until it gains my trust or until I re-stud the rear.
I give these a tentative seal of approval and a solid 8.5/10
No real reason I can't give it a 9 or 10, but this is the score it gets. Because whether or not they're good, there's always going to be better ones that have a reservation at the table of tens.
Hope some poor soul who likes to read found this a helpful and slightly humorous review. Peace.
Reactions: 1
wheel spacers ?
WhistlinDiesel has entered the chat
Tire Wheel Vehicle Automotive tire Motor vehicle
wheel spacers ?
He did it again?!? Doesn't look like he's wearing the homestead drip tho... What a shame.
^ not on, lame
OUTTAKE:
yea spacers are always a last choice as it is a lot of stress on bearings if the off set is not just right.
but in a pinch they work ok.
these days you can get real cash tied up in wheels and tires.
so i can see where you would use them to get another brand of oem wheel as scrap to fit.
i have seen wheels only run 500 to 1000 usd now for some of the exotic wheels.
i have a scrapper friend that gets 25 bucks a wheel for the aluminum wheels.
but you have to pick and sort and take your chances.
the salvage yards are out of sight on parts these days.
Yeah at my u-pull yard they don't really save any wheels. They always sell off all the oem ones to this group of Spanish dudes and get posted on ebay. Spares get welded into stands for the cars, aftermarket rims make it to the main building to be sold for nearly new price even though they looked like they were dragged all the way there, and they don't even try with the rims if they have a lock lug on it. Needless to say, it's difficult finding a good set of wheels.
Though aside from using the spacers to hopefully clearence the fluid resivoir (which worked). I also just did it because it looks nicer. It isn't permanent, for sure. because I want to do open rally in this thing sooner or later, which means getting some proper wheels and tires, better suspension, and potentially a little fabrication to reinforce the control arms in the front and back. and the trailing arm in the back. It's one of those sports where no matter what vehicle you have, you can still have a blast. I did it last year and the year before bone stock but curiosity is catching up to me and I want to see what I can do with some upgrades.
I'll guess that this truck (left front tire; all wheels sticking out some) had wheel spacers. Lever-arm physics in demonstration, twice:
To add insult to injury, the loose tire hits the victim-vehicle again at the end.
P.S. OEM wheels, or new rims with the desired backspacing/fender clearance/flares+flaps; if not, better have USD5 million or more of liability insurance that covers you if non-OEM equipment installed.
I'm aware of the horror stories. Fact of the matter is out of the millions of cars with spacers on the road today. You're focusing on the few cases a massively heavy truck with a ridiculous amount of spacing that was definitely not rated for the vehicle.
I did, however, find and sourced out a spacer set that is rated well over my vehicles weight, and unlike a Chevy, I trust my car not to fall apart from such a negligible change in lever position.
The lever forces in action from a 1.25 increase in offset are negligible, just enough to feel a little different of course. barely a visual difference unless you're looking for it too.
And I wouldn't be running wheels from a Hyundai Santa Fe if I owned a set of OEM wheels, mate. And I've been desperately searching for some tri-spokes for it.
Your input is appreciated but I know what the cost is and I know the physics. Plus, help me out here. if you see a truck or car or even grandma's easy rider with it's wheels outside of the fender wells, report their plate. It's illegal in all but a few states to have an unprotected wheel.
