1 - 10 of 10 Posts
Where can I get a rear visor for my 2000 4.1 ?
Do any of them attach without using two way tape only ?
Not interested in those that require drilling to mount .
....Thanks
I think the best wing that comes ready to install without drilling is the Aerowing made by GTS (GT Styling) www.gtstyling.com
If you need some pics I have pics of the Aerowing and also the Aerowing VS stock wing... :D
ccaddy said:
DJ : That would great if you could :)
Here is one pic, side by side compared to the stock accessory shade... The Green RAV is the Aerowing... 8)
I will try to add a few more pics once I can remember the links... :D
ccaddy said:
DJ : If you have a wing on your RAV , which one is it ?
....Craig
That's my RAV... the Green one... 8)
Please excuse the tires, I have since swapped out the tires with stock tires.... Here are a few more views...
Discussion Starter #9
Ahh , I thought so . Nice ride .
Your spoiler is held on with 2 way tape only , right ?
How long have you had it on and how has it held up ?
Unlike window vent visors , the rear spoiler is constantly
exposed to the lifting force of the wind rushing through it thus
pulling up on the taped surface .
This situation mildly concerns me but not as much as drilling some holes into the vehicles painted surfaces to mount other visors .
Do you have a pic of the other companies visor ?
Thanks...
The Aerowing has been on for quite a while now.... as long as you buy it new, the 3M adhesive tape is already on the Aerowing... It comes with some tiny little alcohol cleaning pads so you can wipe down the surface before applying.... just make sure it's lined up properly before applying because that 3M tape is strong... :D
I don't have any other pics of other ones, the stock one is more of a deflector then wing.... The Aerowing has a bunch of holes on the top part to allow the flow of air through so I believe that also helps it from coming off... :wink:
1 - 10 of 10 Posts
