1 - 10 of 10 Posts
Looks like on my I4 with a 4 speed auto 2,000 rpm is some where between 55mph and 60 mph.
Sooo..
For those of you with the V6 and a 5 speed auto, what is your speed at 2,000 rpm :?:
G
Yep, 55-60 is well below 2000 rpm. Wife never lets me drive it, but 55MPH is close to 1500-1600 rpm ...if I remember right.
Differential number is same for both v6 and I4 with AWD. Ratio is a little lower, (bigger number) for v6 than I4 if they are 2wd.
V6 has much lower rpm gearing in 5th .77 vs 1.02 for I4 in 4th. 70 is about 2000 rpm with V6
I have a pdf with lots of detail RAV4 specs but do know how to post it here.
I can see where the great highway mileage is coming from for the V6.
It is hardly working at highway speeds.
Most of my highway driving with 5AT is around 75-80mph with the tachs around 2000-2400rpms. :D I just shift over to 4th when I need some quick passing power.
Discussion Starter · #9 ·
Here is a link to JimD4's spec file
RAV4 Specs
4-speed ECT automatic (2WD/4WD)
1st 3.943/3.938
2nd 2.197/2.194
3rd 1.413/1.411
4th 1.020/1.019
Reverse 3.145/3.141
Differential 2.923/3.080
5-speed ECT automatic (2WD/4WD)
1st 4.235/4.235
2nd 2.360/2.360
3rd 1.517/1.517
4th 1.047/1.047
5th 0.756/0.756
Reverse 3.378/3.378
Differential 3.080/3.080
Hmmm, looks like adding the rear sway bar and/or the heavier front sway bar of the 3rd seat models to the non-3rd seat models would be a way of improving handling without having to wait for the aftermarket to catch up.
Thx Jim and SW!!
Tim
1 - 10 of 10 Posts
