I’m new here and looking at OEM 2017 Subaru WRX STI Rims 18X8.5. Not sure what the offset is but will it fit and clear suspension and calipers? Please help I need buy something now since my wheel is damaged and need replacement.
Even knowing the offset doesn't mean the spokes will clear the calipers. Probably will need to wait to see if someone else has tried to install them.
Most Subaru vehicles have over time moved from 5x100mm to 5x114.3 bolt spacing, so that spec is OK. But I believe that most Subaru center hub bore size is still smaller than the 60.1mm size Toyota uses.
2017 WRX STI hub bore is 56.1, Gen3 Rav4 are all 60.1
Uswheeladapters.com sell custom wheel adapters where you can choose the 60.1 hub size and the can make it fit a 56.1 wheel. Over $300 for a full set - Not cheap, but possible... not worth it IMO.
