These are the part numbers for the regulators WITH the motors:
REGULATOR ASSY, FRONT DOOR WINDOW, LH : 69820-42100 W(POWER WINDOW) (09/1997 - )
REGULATOR ASSY, FRONT DOOR WINDOW, RH : 69810-42041 W(POWER WINDOW)
If you need just the regulators:
REGULATOR SUB-ASSY, FRONT DOOR WINDOW, LH 69802-42021
REGULATOR SUB-ASSY, FRONT DOOR WINDOW, RH 69801-42021
You wouldn't like to discover the prices of these OEM parts though...
I definitely do not know about the different pin issue, but couldn't it account for the difference between the driver's and the passenger's side control switch panels?Research shows others with issues with 2 pin and 5 pin variants, but no specific part numbers. Consensus looks that a 96-97 used a 2 pin while the 98-00 used a 5 pin. Please correct me if i'm wrong.
