1 - 17 of 17 Posts
2010 RAV4 sport
I just replaced my bottom window seals after 10 years but unfortunately they had degraded terribly, even lost three speakers which is a different subject, but the degraded seals, front passenger even melted a bit, left stripes down both fr & r passenger side windows. I have tried glass cleaner, Dawn dishwashing liquid, and a little bit of alcohol on a test spot. none of these things serve to do anything but smear whatever this residue is. Any ideas? Thanks!
I've seen this a little on my 2008. Ronsonol or Zippo lighter fluid will clean it off. Seems the rubber deteriorates and starts turning into goo.
2011 Barcelona Red Rav4 Sport
Inside or outside? Soap/water with a single-edge razor blade should work. But, if you have your windows tinted, don't use it on the inside.
Reactions: jcb123rav4um
2010 RAV4 sport
It's on the outside. The seals degraded to the point that in places they were like tar which is what is on my windows. I have tried soap and water. Another suggestion was lighter fluid. What do you think?
2010 RAV4 sport
Exactly! Like tar. That goo smeared its way up my front passenger side window. Lighter fluid huh? I've been trying to figure out what the substance is that would cut this stuff. I'm not down with the razor blade and soap and water solution since soap and water did absolutely nothing. I have not tried scraping with a razor blade but I'm also not trying to etch my windows. Window seals are cheap, windows are not! Thanks for the tip.
I use razor blades on windows all the time to remove old window film glue without any issues at all. The soap/water is just as a slip solution. I don't like the idea of lighter fluid because I don't know what it would do it it accidentally ran down onto the painted surfaces of the door.
2010 RAV4 sport
Discussion Starter #7
All good points. And I certainly don't want lighter fluid on my brand new seals.
I'll let you know what results I get!
Well, don't spray lighter fluid all over the glass and let it drip down! Just wet a small spot on a paper towel or rag and rub it over the tar. It will take it off.
2010 RAV4 sport
Discussion Starter #9
🤣🤣🤣 Of course not!!🤣🤣🤣
Sorry for making it sound like I was That level of inexperienced. ☺ Will do!
2010 RAV4 sport
Discussion Starter #11
Basically the same results as lighter fluid you think or better? I have used goo gone, mostly in retail to remove price tag adhesive etc.
2010 RAV4 sport
Discussion Starter #13
Certainly. It's citrus based. I would still protect my new seals but I'll likely try it out. Needed a bottle anyways. ✌
1 - 17 of 17 Posts
