While installing an aftermarket radio in my 2016 RAV4 LE. In the process of wiring up the backup camera to the deck and the steering wheel controls. I got locked out of my transmission and the windows will no longer go up. Anyone have any ideas what might be going on here?
You may have shorted some wired. I would first check the fuse box look for any blown fuses and replace them.
Sent from my Pixel 3 using Tapatalk
I found a blown 5A fuse in the drivers side IGN 2 slot but I'm having trouble finding the fuses. Not sure it'd be wise to put a bigger fuse in it or not.
2011 Barcelona Red Rav4 Sport
Sort of off-topic, but which adapter did you use for the steering wheel controls?
2013 RAV4 XLE AWD
Not OP, but I used Crux harness for everything.
Reverse camera, steering wheel control, stock USB port retained for carplay. Great harness.
Steering wheel control includes volume up/down and Reverse and forward track. Also input change like tuner to BT.
