1 - 2 of 2 Posts
N
The plastic parts that is located on the bottom corner of the windscreen is breaking off. I can't describe the part with the right word, but that part seems to have been glued together to the main rubber seal at factory and after a period of time it will fall off. This plastic part is used to allow the water to run off at the bottom of the corner of the winscreeen. I think this problem is common, since it occured on both side of the parts on my RAV. :shock:
I have to glue these part regularly, I did it last year and now it came off again.
So watch out, and do a regular check before you loose this part
when it fall off.
1 - 2 of 2 Posts
