1 - 2 of 2 Posts
Hey guys, I've never had to replace the tubing on one of these bad larrys. Thought it would be a straight forward pop it in and go but the tubing also goes to the rear and I don't know how to access it. It's a 1997. Any help would be appreciated!!
I would check both ends for problems before resorting to full replacement.
Once you get all the junk out of the way it is easy to see the hose.
But to get to the hose start with removing the right rear seat, then open the back door and remove the door panel, remove the threshold for the back door and both of the thresholds on the right side doors, remove the right side plastic trim panel from the cargo area, remove the right front kick panel and the right front inner fender.
There it is!
It would be the last part of that system, I would want to replace.
Good luck.
1 - 2 of 2 Posts
