1 - 2 of 2 Posts
Does anyone know if there is a 12 volt supply behind the dash?
I want to wire up a video camera that would be on when the ignition is on
Also a phone holder. Both only need power when ignition is on
1) Is there a feed of 12 volts unused in the dash area?
2) Does anyone have a wiring diagram
Many thanks
Sure, why not use the 12 volt switched power to the radio? There is also a 12 volt constant wire to the radio to keep the stations programmed in memory--you don't want that one.
Or, you could tap into the fuse box. There should be a fuse box under the dash.
1 - 2 of 2 Posts
