I'm looking into buying an XSE hybrid, but my commute is mostly freeway, little traffic. What kind of mpg should I expect?
You should be able to get the rated gas mileage or a bit better. I have never gotten less than 39 MPG (rated 38 MPG highway) on my XLE Premium hybrid. With mixed driving, I always get 42 to 49 MPG.I'm looking into buying an XSE hybrid, but my commute is mostly freeway, little traffic. What kind of mpg should I expect?
Were you using the A/C much?I recently drove from Southern California to Las Vegas, which is basically 100% freeway at speeds of around 80mph and I got 39mpg on the way out there and 40mpg on the way back.
This isn't exactly a question that can reasonably be answered with so little information. What kind of winds do you face? What type of elevation gain / loss are you driving? What are the temperatures like typically? How fast do you plan to drive? How far is your trip?I'm looking into buying an XSE hybrid, but my commute is mostly freeway, little traffic. What kind of mpg should I expect?
Based on my experience it depends. If you are heavy on the gas or go over 80 MPH you will get low 30's. If you take it a bit easy on the gas and don't go above 80 MPH then you can get close to 40. It's possible to get over 40 as well.I'm looking into buying an XSE hybrid, but my commute is mostly freeway, little traffic. What kind of mpg should I expect?
I have an XSE. I live in Florida (flat roads) so the A/C is on all the time. I get about 38 on the highway. I have roof rails, carry about 200LB of tools, keep tire pressure at 35 PSI and speed is about 70 MPH. For me, I get better MPG on the highway even though I drive conservatively. I keep the car in Eco mode all the time.I'm looking into buying an XSE hybrid, but my commute is mostly freeway, little traffic. What kind of mpg should I expect?
Yes A/C was on 100% of the time as the temps were 90-100 degrees outside.Were you using the A/C much?
My experience after driving my RAV4 Hybrid for 2 summers (and 2 winters) has been that using the air conditioning, even when temperatures are above 90 F, has only minimal effect on fuel economy. While very hot outdoor temperatures have minimal effect on fuel economy, it is the extreme winter cold temperatures, especially when temperatures are below 10 degrees F, that will have the biggest negative effect on fuel economy.Yes A/C was on 100% of the time as the temps were 90-100 degrees outside.
However, use of ECO mode will have its biggest positive effect on fuel economy when you use it in town. When you use ECO mode on the freeway, its benefits will be minimal because ECO mode helps fuel economy the most when you are more likely to be changing speeds frequently, which is not as likely to be the case with freeway driving.I use normal mode around town and eco mode on freeway.
I will experiment with it. I’m still learning about hybrid system. I was given that advice by the dealership. The guy who set up the car for me. And uTube video from Car Care Nut.However, use of ECO mode will have its biggest positive effect on fuel economy when you use it in town. When you use ECO mode on the freeway, its benefits will be minimal because ECO mode helps fuel economy the most when you are more likely to be changing speeds frequently, which is not as likely to be the case with freeway driving.
