Hey all,
This is my first post. Thanks in advance for your thoughts and suggestions!
Our 2007 v6 (205,880 km) was running great. My wife took it in for an oil change during which they also replaced the air filter, which apparently was pretty dirty. At any rate ... we went camping right after and while away, the check engine, VSC, and 4wd lights came on. As soon as we got back we took it in to run a diagnostic ($109 to retrieve the codes and run the diagnostic! an aside: anyone have a suggestion on a budget code reader?), which brought up three codes:
P0102 - Mass or volume flow sensor
P0113 - Intake Air Temperature Circuit High Input
P2195 - O2 Sensor Signal Biased/Stuck Lean
I tried cleaning the mass air flow sensor, let it dry, and then cleared the warning lights by disconnecting the battery but they came back on a day later. My next step was going to be purchasing a mass air flow sensor and an O2 sensor and replace them myself (quoted just over $800 for Canadian Tire to do it! the mass airflow sensor change is $390 ... i mean that thing takes like two seconds to take out and replace!), but something keeps nagging at me. It seems strange to me that these codes would pop up right *after* changing the air filter (especially since problems with the sensors are caused by dirty filters). Does this seem strange to any of you? Any chance these are being caused by some mistake made while replacing the filter? A loose intake? Something?
Any thoughts/suggestions greatly appreciated!
Cheers
Cheers
